[OpenLayers-Dev] OpenLayers release blockers?
Schuyler Erle sderle at metacarta.com
Sat Jan 20 13:35:44 EST 2007
On Sat, 2007-01-20 at 13:30 -0500, Christopher Schmidt wrote:
> > This batch script isn't necessary any more and ought to be removed. See
> > http://trac.openlayers.org/wiki/Profiles for more details. The new
> > build.py added in r2097 (and tested successfully) makes this
> > unnecessary. Also, this ticket #385 should be closed.
> The pullup for #385 fixes the fact that the build didn't include the
> license. See http://trac.openlayers.org/ticket/385#comment:5 and
> following.
> I don't see a batch script in SVN on either the branch or trunk:
> http://svn.openlayers.org/branches/openlayers/2.3/build/
ok, then it's just the ticket description that's out of date. ;-) no
problem.
SDE
More information about the Dev mailing list
