[OpenLayers-Dev] Need Help Using Multiple Map Files
Brian Krebs bkrebs at korterra.com
Mon Jan 22 10:38:47 EST 2007
Well, the good news is that it's not ka-Map.  The bad news is I'm an
idiot.  The mapName parameter was being passed as uppercase, but they
were listed in config.php as lowercase.  I updated that so they are
uppercase and all is well now.
Thanks for your help and quick responses.
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Monday, January 22, 2007 8:41 AM
To: Brian Krebs
Cc: dev at openlayers.org
Subject: Re: [OpenLayers-Dev] Need Help Using Multiple Map Files
On Mon, Jan 22, 2007 at 08:09:22AM -0600, Brian Krebs wrote:
> No, it brings up the exact same tile.
In that case, the problem is with the ka-Map serverside generation
script. At the moment (probably for the next few days) I don't have time
to dig into the ka-Map tile generation code.
You might try looking into TileCache, or looking at the PHP code in
ka-Map and seeing if you can figure out why it's happening.
Sorry I can't be of more assistance at the moment.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
