[OpenLayers-Dev] Integrating Google Maps and Mapserver
Bradley Mclain bradleym06 at gmail.com
Tue Jul 3 00:41:01 EDT 2007
Ok this doesn't seem to be necessary can't I just use OpenLayers to tile? My
main problem is just getting OpenLayers to display the Mapserver WMS data
which is now correctly working (I can now query the WMS properly outside of
openlayers) .
Would it be easier to get a wrapping script working because i can't get that
to work at the moment and all of the examples so far seem to be using a
wrapping script of some sort.
On 7/3/07, Bradley Mclain <bradleym06 at gmail.com> wrote:
> Its good its working now, I'll have a look through it and see what i can
> do.
> On 7/3/07, Bradley Mclain <bradleym06 at gmail.com > wrote:
> > Thanks how do i get to the configuration script?
> > On 7/3/07, Anselm Hook <anselm at gmail.com > wrote:
> > > Those are ~probably~ done as a cgi alias?  And / or the actual
> > > composition of specific arguments is handled in javascript?
> > > A while back I put together an example at civicmaps.org - I notice
> > > that the home page is broken at the moment, but the configuration script
> > > there may help.
> > > I must admit setting these things up can be a hassle.
> > >  - a
> > > On 7/1/07, Bradley Mclain <bradleym06 at gmail.com > wrote:
> > > > Also just thought that I'd mention that my Mapserver is not properly
> > > > set up as a WMS and it will be quite difficult to do so so I'd rather use
> > > > the cgi mode of Mapserver. However when looking at the Mapserver examples I
> > > > failed to see anything at all which resembled this. It calls "
> > > > http://labs.metacarta.com/wms/vmap0" but shouldn't there be a
> > > > "cgi-bin/mapserv?map=" somewhere.
> > > > Cheers
> > > > Brad
> > > > On 7/2/07, Bradley Mclain <bradleym06 at gmail.com> wrote:
> > > > > Ok I made some progress but I have hit a few roadblocks. At the
> > > > > moment my code successfully displays the google map, hybrid and satelite
> > > > > images. However only if it is opened from its current location if I try to
> > > > > open it on my server, i get an error displaying that my google maps api does
> > > > > not correspond. However even when i registered a new one for
> > > > > http://192.168.1.130 (my server address) the page simply displays
> > > > > as plain white.
> > > > > My second problem is getting mapserver to display. Below is my
> > > > > current attempt to get it to work. What am supposed to call the mapfile?, or
> > > > > direct it to the url of the working map?
> > > > > <html>
> > > > > <head>
> > > > >   <script src="http://maps.google.com/maps?file=api&amp;v=2&amp;key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ<http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ>"
> > > > > type="text/javascript"></script>
> > > > >     <script src="../lib/OpenLayers.js"
> > > > > </head>
> > > > > <body>
> > > > > <h4>Debortoli Wines OpenLayers Test</h4>
> > > > >   <div style="width:100%; height:80%" id="map"></div>
> > > > >   <script defer="defer" type="text/javascript">
> > > > >     OpenLayers.ProxyHost="/proxy/?url=";
> > > > >     var map = new OpenLayers.Map( 'map', {controls: [new
> > > > > OpenLayers.Control.PanZoomBar()]} );
> > > > > //Adding Controls
> > > > >     map.addControl(new OpenLayers.Control.MouseToolbar());
> > > > >     map.addControl(new OpenLayers.Control.MousePosition ());
> > > > >     map.addControl(new OpenLayers.Control.Permalink());
> > > > >     var layer_switcher = new OpenLayers.Control.LayerSwitcher();
> > > > >     map.addControl(layer_switcher);
> > > > >     layer_switcher.maximizeControl();
> > > > > //Adding Layers
> > > > >     var google = new OpenLayers.Layer.Google("Google");
> > > > >     var googles = new OpenLayers.Layer.Google("Google Satellite",
> > > > > { 'type': G_SATELLITE_MAP });
> > > > >     var googleh = new OpenLayers.Layer.Google("Google Hybrid", {
> > > > > 'type': G_HYBRID_MAP });
> > > > >     var mapserv = new Openlayers.Layer.HTTPRequest("Debortoli
> > > > > Mapserver", "http://192.168.1.130/cgi-bin/mapserv?map=/usr/local/mapfiles/dbw.map&layers=dbap&mode=browse
> > > > >     map.addLayers([google, googles, googleh, mapserv]);
> > > > >     map.setCenter(new OpenLayers.LonLat(135,-28), 4);
> > > > >   </script>
> > > > > </body>
> > > > > </html>
> > > > > > Cool I'll look into that and get back to you with my progress.
> > > > > > Currently having issues getting my google map to display, its just shows up
> > > > > > as white. I registered a new key and everything.
> > > > > > On 7/2/07, Anselm Hook <anselm at gmail.com> wrote:
> > > > > > > Oh, actually that example is not perfectly clear; it doesn't
> > > > > > > expressly illuminate that you can choose to leave more than one layer on at
> > > > > > > a time....  in any case you can do so.
> > > > > > >  - a
> > > > > > > On 7/1/07, Anselm Hook <anselm at gmail.com> wrote:
> > > > > > > > http://openlayers.org/gallery/multiple.html
> > > > > > > > On 7/1/07, Bradley Mclain < bradleym06 at gmail.com> wrote:
> > > > > > > > > Hey
> > > > > > > > > What I am looking to do is to integrate Google Maps with a
> > > > > > > > > custom map which is being served from Mapserver. I currently have Mapserver
> > > > > > > > > working and serving the correct layers. I just have a few questions about
> > > > > > > > > this which I am hoping you can answer.
> > > > > > > > > Is it possible to use openlayers to integrate the two?
> > > > > > > > > If not, are there any other possible programs which I can
> > > > > > > > > use to do this?
> > > > > > > > > If so, how do I go about this?
> > > > > > > > > Cheers
> > > > > > > > > Brad
> > > > > > > > > _______________________________________________
> > > > > > > > > Dev mailing list
> > > > > > > > > Dev at openlayers.org
> > > > > > > > > http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070703/b393a68b/attachment.html
More information about the Dev mailing list
