[OpenLayers-Dev] OpenLayers Internationalization
Steven M. Ottens
steven at minst.net
Fri Jul 13 04:33:43 EDT 2007
Hi chris,
Gertjan wrote the i18n support for mapbuilder, so it might be
interesting to discuss it with him as well.
We use a mbGetMessage function (/lib/util/Util.js) which gets called
with either just the message key or together with some extra parameters:
alert(mbGetMessage("noTargetModelTool", targetModelName, toolRef.id));
corresponds with:
<noTargetContext>Error finding targetContext: {0} for: {1}</noTargetContext>
All the strings are located in a widgetText.xml document, which is
located in the skin/<lang>/ folder
Regards
Steven
Christopher Schmidt wrote:
> Couple questions for internationalization:
> Current strings included in the OpenLayers Library which are likely
> candidates for i18n (incomplete):
> Ajax.js:37: alert("Unhandled request return " + request.statusText);
> Control/OverviewMap.js:537: alert('The overview map only
> works when it is in the same projection as the main map');
> Format/GeoRSS.js:124: alert("Couldn't parse " +
> geometry.CLASS_NAME);
> Format/WFS.js:126: if (!feature.fid) { alert("Can't update a
> feature for which there is no FID."); }
> Format/WFS.js:161: alert("Can't update a feature for which
> there is no FID.");
> Format.js:42: alert("Read not implemented.");
> Format.js:56: alert("Write not implemented.");
> Layer/GML.js:129: alert("Error in loading GML file "+this.url);
> Layer/Vector.js:172: alert(message);
> var message = "Your browser does not support vector rendering. " +
> "Currently supported renderers are:\n";
> message += this.renderers.join("\n");
> Layer/WFS.js:376:
> this.commitReport('WFS Transaction: SUCCESS', response);
> this.commitReport('WFS Transaction: FAILED', response);
> * How much support do we need for interpolation in text? I think that
> the answer for this at the moment is "none" -- that is, all
> translated text will be literal, exact matches for the time being,
> with no interpolation of variables into the middle of strings. This
> may change in the future. Depending on how it changes, more complex
> support for pluralization may also be needed. For the time being, I'd
> like to ignore all of this and just pretend that we want simple
> string translations unless someone tells me otherwise.
> * In general, translation libraries use a short function name to
> indicate "translate this string." (I think a common use in C is the
> "_" function, via the gettext library or what have you.) In
> OpenLayers, we try not to squash other people's namespaces. I'd like
> to use OpenLayers._ for translation, as opposed to
> OpenLayers.Strings._ or something similar.
> * I think the simplest thing to do is to have a single Javascript file
> with the Strings in it (lib/OpenLayers/Strings.js), and a default
> language. Then, to change the language, all you need to do is
> something like:
> OpenLayers.Strings.language = "fr";
> before you start working with the UI. Does this seem sane? the
> file might look something like this:
> OpenLayers.Strings = {
> 'en': {
> // Message reported via alert when WFS transaction succeeds
> 'olLayerWFSSuccessMessage': 'WFS Transaction: SUCCESS'
> 'es': {
> 'olLayerWFSSuccessMessage': 'WFS Transaction: e`xito!'
> '1337': {
> 'olLayerWFSSuccessMessage': '5|_|CC35'
> OpenLayers.Strings.language = 'en';
> Is there anything that anyone can think of that would make this
> totally infeasible?
> Regards,
More information about the Dev
