[OpenLayers-Dev] OpenLayers Internationalization
Erik Uzureau
erik.uzureau at metacarta.com
Fri Jul 13 11:35:44 EDT 2007
I think the latter idea is excellent. Controls are the only thing
which will ever
have permanent visual text blocks, so this will solve the problem very nicely.
good one!
e
On 7/13/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Fri, Jul 13, 2007 at 10:08:17AM -0500, Erik Uzureau wrote:
> > Do we want to have support for live switching of languages?
> > ie whenever a string is added to the interface (so not for log/warns),
> > it would register the component with the string manager, then when
> > user says OL.StringManager.setLanguage("catalan") it would cycle
> > through and update alll the live components?
> I don't think so. I think, since layers won't have text in them, that
> changing the language can then have the user remove and destroy any
> existing controls, and then re-add them after switching the 'current'
> language. That way, you don't have a complete reset of your map, but you
> also don't have the complexity of trying to change existing DOM elements
> either.
> Alternatively, controls could have a 'redraw()' function, which would
> actually cause the control to essentially start over from scratch -- in
> this way, a 'setNewLanguage' would just be a language='foo', followed by
> looping over the controls (or anything which displays text) and
> redrawing it.
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
