[OpenLayers-Dev] moving tiles on top of gmaps
Steven M. Ottens steven at minst.net
Mon Jul 16 08:43:49 EDT 2007
Hi all,
I have found a strange behavior with openlayers in combination with
google maps; The tiles of a WMS layer do not match those of the google
layer. This isn't a bad thing per se, but if you resize the browser
window, different tiles are requested from the WMS server.
This makes it virtually impossible to cache those tiles and result in a
horrible performance.
You can see this behavior in the google.html example. Outline both block
level elements and images and you will see that the block level elements
(DIVs with WMS tiles) change their offset with the images (Google-tiles)
when you resize the window.
Has anyone managed to setup OpenLayers with google maps and a
cachable-WMS*) layer on top of it?
*)preferably a tilecache setup.
regards,
Steven
More information about the Dev mailing list
