[OpenLayers-Dev] new class style
Tim Schaub
noreply at geocartic.com
Mon Jul 16 19:15:04 EDT 2007
As of revision 3767[1], we'll be using a new syntax for class definitions.
Old syntax:
var MyClass = OpenLayers.Class.create();
MyClass.prototype = OpenLayers.Class.inherit(BaseClass, {
// class def here
New syntax:
var MyClass = OpenLayers.Class(BaseClass, {
// class def here
Until 3.0, you can use the create and inherit methods - and old style
classes can inherit from new style classes. After 3.0, only the new
syntax will be supported. With this change, all classes in the library
use the new syntax.
Tim
[1] http://trac.openlayers.org/changeset/3767
More information about the Dev
