[OpenLayers-Dev] moving WMS tiles over Google
Steven M. Ottens
steven at minst.net
Wed Jul 18 04:46:10 EDT 2007
Hi all,
I noticed some weird behavior of WMS tiles in combination with google
maps. The bounding box of the WMS tiles is not constant when resizing
the map. The tiles are moving in respect to the google tiles. The
behavior is the most visible in the current trunk, since the tiles move
both horizontal and vertical.
But the 2.4 release suffers from the same problem; the tiles move
vertically.
I've only investigated trunk thoroughly and discovered that it's caused
by Google recentering the map after a resize:
After a resize Map.setCenter is called this retrieves the current
Extent, which is the one after the resize, but before the
Google-triggered resize. This extent is stored as bounds and this bounds
is used later on by Grid.initGriddedTiles to calculate the number of
rows and columns and their position over google maps.
At this point Google has changed the extent and the calculated WMS-tile
position is off by half the resize distance. This new tile location is
used by Tile.getBoundsFromBaseLayer to calculate the Tile bounds. These
tile bounds are calculated against the new Extent and as such fit over
the Google layer.
Since everything fits it's hard to notice the problem, the easiest way
is to outline both the DIVs (WMS layer) and the Images (google layer)
and resize your window.
I found that using the current Extent in Gid.initGriddedTiles solves
both the horizontal and vertical movement. I added
bounds=this.getExtent(); as the first line of the function, overruling
the bounds which is given from Map.setCenter. I also noticed that in
previous version Grid.initTile (the predecessor of initGriddedTiles)
used bounds=this.getExtent so I'm curious why this has changed, can
anyone enlighten me? (also I'm wondering why 2.4 with initTile still
suffers from vertical movement)
Regards,
Steven
More information about the Dev
