[OpenLayers-Dev] {} or new Object()
Erik Uzureau erik.uzureau at metacarta.com
Tue Jul 24 16:07:26 EDT 2007
This thread is talking about "{}" and "new Object()", both of which
are standard JavaScript, and neither of which has anything to do with
On 7/24/07, John Cole <john.cole at uai.com> wrote:
> I'll second the caution about prototyping basic items.  I've found that you
> cannot use M$ ajax framework with some prototype.net based kits because they
> define the same thing differently.
> I don't think OL should assume that it's the only JavaScript kit on the page
> and would prefer it to use standard JS when possible.
> My $.02
> John
> -----Original Message-----
> From: dev-bounces at openlayers.org [mailto:dev-bounces at openlayers.org] On
> Behalf Of Jeff Dege
> Sent: Tuesday, July 24, 2007 2:51 PM
> To: dev at openlayers
> Subject: Re: [OpenLayers-Dev] {} or new Object()
> Which is more likely to cause conflicts with other javascript class
> frameworks?
> Everybody and his brother seems to override $(), which causes no end of
> headaches.
> > [mailto:dev-bounces at openlayers.org] On Behalf Of Erik Uzureau
> > Sent: Tuesday, July 24, 2007 2:43 PM
> > Subject: [OpenLayers-Dev] {} or new Object()
> > Paul has just gone vocal with his preference for using {} instead of
> > "new Object()" for the instantantiation of a new object.
> > We do not currently have any policy for this. Do people feel strongly
> > one way or the other?
> > Obviously it's not a big issue, but if there is broad support for
> > doing it one way or the other, we might as well attempt to standardize
> > a bit.
> > Erik
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> Dev mailing list
> This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
> Dev mailing list
More information about the Dev mailing list
