[OpenLayers-Dev] $()
Erik Uzureau
erik.uzureau at metacarta.com
Tue Jul 24 16:19:47 EDT 2007
furthermore, as pointed out by cr5, the $() only gets assigned by OL
if it was not previously assigned by another library.
Which means that folks are safe because if it gets assigned *after* OL
loads, that's perfectly fine (since we don't use it ourselves)
On 7/24/07, Erik Uzureau <erik.uzureau at metacarta.com> wrote:
> FWIW, OpenLayers is moving *away* from defining the $() operator as
> defined in Prototype. We no longer include the Prototype library in
> our build. Instead, we have cherry-picked some of the convenient
> functions that we like from the library.
> For the moment, the $() *is* still maintained in the OL release,
> though you will notice that it is marked as deprecated and is not
> actually used anywhere in the trunk. We would like to pull it
> altogether, but unfortunately some OL users might depend on it and
> we're trying not to break API until we do the 3.0 release.
> ---------- Forwarded message ----------
> From: John Cole <john.cole at uai.com>
> Date: Jul 24, 2007 3:01 PM
> Subject: Re: [OpenLayers-Dev] {} or new Object()
> To: Jeff Dege <jdege at korterra.com>, "dev at openlayers" <dev at openlayers.org>
> I'll second the caution about prototyping basic items. I've found that you
> cannot use M$ ajax framework with some prototype.net based kits because they
> define the same thing differently.
> I don't think OL should assume that it's the only JavaScript kit on the page
> and would prefer it to use standard JS when possible.
> My $.02
> John
> -----Original Message-----
> From: dev-bounces at openlayers.org [mailto:dev-bounces at openlayers.org] On
> Behalf Of Jeff Dege
> Sent: Tuesday, July 24, 2007 2:51 PM
> To: dev at openlayers
> Which is more likely to cause conflicts with other javascript class
> frameworks?
> Everybody and his brother seems to override $(), which causes no end of
> headaches.
> > [mailto:dev-bounces at openlayers.org] On Behalf Of Erik Uzureau
> > Sent: Tuesday, July 24, 2007 2:43 PM
> > Subject: [OpenLayers-Dev] {} or new Object()
> > Paul has just gone vocal with his preference for using {} instead of
> > "new Object()" for the instantantiation of a new object.
> > We do not currently have any policy for this. Do people feel strongly
> > one way or the other?
> > Obviously it's not a big issue, but if there is broad support for
> > doing it one way or the other, we might as well attempt to standardize
> > a bit.
> > Erik
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> Dev mailing list
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed. If you have received this email in error please notify
> the sender. This message contains confidential information and is
> intended only for the individual named. If you are not the named
> addressee you should not disseminate, distribute or copy this e-mail.
> Dev mailing list
More information about the Dev
