[OpenLayers-Dev] OpenLayers dragging issue
Bill Woodall
bwoodall at bwoodall.org
Fri Jul 27 13:27:30 EDT 2007
Hi Devlist
A while back VMX had a small patch to Events.js that throttled the
triggerEvent() on mousemoves ( see the updated patch below ). Not sure
if it ever got a ticket.
........Bill,
Index: lib/OpenLayers/Events.js
--- lib/OpenLayers/Events.js (revision 3789)
+++ lib/OpenLayers/Events.js (working copy)
@@ -382,6 +382,20 @@
fallThrough: null,
+ * APIProperty: lastEventMM
+ * {Integer} simple counter to keep down the number of trigger
+ * events while 'mousemove' is happening
+ lastEventMM: 0,
+ * APIProperty: EventMMThreshold
+ * {Integer} threshold for the number of 'mousemove' before
allowing
+ * an event trigger
+ EventMMThreshold: 2,
* Constructor: OpenLayers.Events
* Construct an OpenLayers.Events object.
@@ -632,8 +646,13 @@
* evt - {Event}
handleBrowserEvent: function (evt) {
- evt.xy = this.getMousePosition(evt);
- this.triggerEvent(evt.type, evt)
+ if (this.lastEventMM < EventMMThreshold && evt.type ==
"mousemove") {
+ this.lastEventMM++;
+ } else {
+ this.lastEventMM = 0;
+ evt.xy = this.getMousePosition(evt);
+ this.triggerEvent(evt.type, evt);
On Fri, 2007-07-27 at 08:53 -0500, Les Szklanny wrote:
> Les Szklanny wrote:
> > Hi,
> > I created a simple demo using OL 2.4 and Scriptaculous 1.7.1 beta 3
> > showing a dragging problem, which I believe is caused by OpenLayers.
> > http://www.slippymap.com/kamap.html
> > Try to quickly drag the 'Powered by Oracle' image. If you are using
> > FF or Safari, the image gets disconnected from the cursor, but it
> > drags quite well on IE 6 and 7.
> > If I comment out the MouseDefaults or MousePosition controls, then
> > dragging becomes very smooth as one would expect. The two controls
> > have handlers that observe mouse movement.
> > Any idea how to fix or work around this problem?
> > Thx,
> > Les Szklanny
> > Where2GetIt
> Hi all and happy Friday :)
> I asked this question a week ago...
> Is there something I can add or clarify? I'm lost how to handle this
> problem.
> Thx,
> Les Szklanny
> Where2GetIt
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
