[OpenLayers-Dev] OpenLayers dragging issue
Les Szklanny
lszklanny at where2getit.com
Fri Jul 27 14:17:18 EDT 2007
Christopher Schmidt wrote:
> On Fri, Jul 27, 2007 at 11:10:59AM -0500, Les Szklanny wrote:
>> Christopher, hi!
>> I'm not sure I understand your response.
>> This is a big deal for me (and probably others) as it means you can't build
>> a draggable marker that drags smoothly.
> http://dev.openlayers.org/sandbox/tschaub/feature/examples/drag-marker.html
> I see that as a draggable marker that drags smoothly. Is that what you
> meant?
> Regards,
Yes, this marker drags smoothly.
I should be able to use it. Thank you!
Les
More information about the Dev
