[OpenLayers-Dev] #736 (external graphic as style for vector
points)
Arthur Noel
art at ischium.net
Fri Jun 1 07:04:07 EDT 2007
Andreas,
(resending as I sent to you direct by mistake)
On 1 Jun 2007, at 11:52, Andreas Hocevar wrote:
> Thanks, I also fixed it, I am waiting for commit access. My solution
> is a little bit different
> node.setAttributeNS(null, "style", "transform: rotate(180)");
If you rotate then the image is the wrong way on the x axis.
Cheers,
Arthur
More information about the Dev
