[OpenLayers-Dev] OpenLayers 2.4 - map mousedown event
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Jun 4 21:00:36 EDT 2007
Christopher,
Do you have any thoughts, advice, a patch maybe to fix this?
Do you want a ticket opened for this issue?
Thanks,
-Steve
Les Szklanny wrote:
> Hi all,
> I discovered that the 'mousedown' event registered on the map object
> will not fire in OpenLayers 2.4.
> It works as expected in OL 2.3.
> I added the following line in the kamap.html example:
> map.events.register('mousedown', this, function() { alert('mousedown')});
> See demo below:
> OpenLayers 2.3
> http://www.slippymap.com/kamap23.html
> OpenLayers 2.4
> http://www.slippymap.com/kamap24.html
> I used IE 6, FF 2, Opera 9.21 and Safari 1.3.2 for testing.
> Please help.
> Les Szklanny
> Where2GetIt
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
