[OpenLayers-Dev] Feature "select detection" implementation
details needed
bkausbk
bkausbk at web.de
Wed Jun 6 19:03:47 EDT 2007
Dear Tim,
> When polygons intersect, the result is one or more points, one or more
> lines, one or more polygons, any combination of the above, or nothing.
> The result of OpenLayers.Geometry.intersect will be a list of geometries.
> Again, OpenLayers.Geometry.intersect doesn't exist. If you are
> interested in working on this (or any of the methods that it will
> require), I'm interested in helping you organize the work.
Hmm, I'm of course interested but I think it wouldn't be easy to implement this
from bottom up.
There should be btw. a method for checking which geometries intersects and a
method for returning intersection points (later one may call the first method)
And what about methods for combining and excluding polygons? See
http://www.kalytta.com/OpenLayers/intersection.html
This could be especially usefull if OpenLayers will be used as feature editor.
PS: Which coordinate system (unit) will be used to store geometry points?
regards
Benjamin Kalytta
More information about the Dev
