[OpenLayers-Dev] adding markers is slow in IE
Paul Spencer
pspencer at dmsolutions.ca
Thu Jun 7 13:18:53 EDT 2007
I had a (non-OL) piece of code that really sucked in IE because of
attaching event handlers to a bunch of small elements in the page -
replacing it with an event handler on the container and then using
the target property to determine if one of the smaller elements had
been clicked solved the problem for me. I haven't looked at Marker
but I would check to see how event handling is done.
Cheers
Paul
On 7-Jun-07, at 1:11 PM, Pierre GIRAUD wrote:
> Does anyone has any idea why adding Markers to a Marker layer is much
> slower in IE than in Firefox ?
> The following code takes 3 to 4 secondes and up to 20 secondes or
> more in IE :
> for (var i = 0; i < 500; i++) {
> var x = Math.random() * 100;
> var y = Math.random() * 100;
> var marker=new OpenLayers.Marker(new
> OpenLayers.LonLat(x,y));
> markers.addMarker(marker);
> Regards
> Pierre
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the Dev
