[OpenLayers-Dev] adding markers is slow in IE
Pierre GIRAUD bluecarto at gmail.com
Mon Jun 11 04:16:00 EDT 2007
Can you give some explanations or examples for non trivial ways to
turn the alpha-hack off ?
Regards
Pierre
On 6/7/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Thu, Jun 07, 2007 at 07:11:57PM +0200, Pierre GIRAUD wrote:
> > Does anyone has any idea why adding Markers to a Marker layer is much
> > slower in IE than in Firefox ?
> > The following code takes 3 to 4 secondes and up to 20 secondes or more in IE :
> transparency. Alpha-PNG transparency is on by default (with no trivial
> way to turn it off), and running the transparency hack on hundreds of
> images takes seconds of time.
> Regards,
> Christopher Schmidt
> MetaCarta
More information about the Dev mailing list
