[OpenLayers-Dev] Using Examples to create Better Documentation
Christopher Schmidt
crschmidt at metacarta.com
Sat Jun 16 14:20:02 EDT 2007
In an effort to use our examples to put together better documentation
targeted towards users, I'm working on a specific way of describing the
metadata about examples such that it can be used by additional tools to
build up a more comprehensive documentation set for our users.
If you look at the source of:
http://dev.openlayers.org/sandbox/crschmidt/docs/docs.html
You'll see that there is some additional metadata in the page:
specifically, the <h1> has a 'title' id, there is a 'tags' div which has
<a> element inside, a p with 'id' shortdesc, and a 'docs' div. The
reason for this is to allow for building of two different forms of
overview of the examples:
* http://dev.openlayers.org/sandbox/crschmidt/docs/docs.html
"Table of Contents" style.
* Categorized page listing (powered by the tags in the example):
http://dev.openlayers.org/sandbox/crschmidt/docs/cats.html
I'm going to work on adding this to all the examples in the branch (or
at least more of them) so we can see what it looks like.
Thoughts?
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
