[OpenLayers-Dev] [OpenLayers-Trac] [OpenLayers] #726: Patch for
toggle type buttons in Panel.js
Christopher Schmidt
crschmidt at metacarta.com
Wed Jun 20 09:44:00 EDT 2007
Andreas, Oliver:
On Wed, Jun 20, 2007 at 11:31:40AM -0000, OpenLayers wrote:
> #726: Patch for toggle type buttons in Panel.js
> Please add tests to this patch. I should have said this to begin with,
> because the nwe would have found this out without needing a second patch.
> Please add a test to trunk/tests/Control/test_Panel.html which checks that
> the expected controls are turned on by activateControl. Your test should
> fail before this patch is applied, and succeed after. If you can write a
> test like that, I'll approve this.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev
