[OpenLayers-Dev] OverviewMap help
Paul Spencer
pspencer at dmsolutions.ca
Wed Jun 27 19:46:37 EDT 2007
looking for help configuring an overviewmap. A quick explanation.
My OL layers are not in a directly valid projection, they are
displayed at a resolution of 1 in what is essentially pixel space.
There is a geo2pix/pix2geo conversion that I can do to convert the
position OL reports as the geographic extents/center into real
geographic coordinates in SRS EPSG:26917.
I would like to add an overview map that points to a WMS service (for
now). I have subclassed the overview map to override the functions
that convert between map space and the overview map space to insert
my custom conversion.
I've got the overview map showing *something* but it is in the
completely wrong location (as far as I can tell) and the tile set for
the overview map is stuck with the bottom/left tile in the center on
the map and no blue box!
I suspect that it is just a matter of me initializing the overview
map wrongly, here is what the relevant code is:
// add keymap
var wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
"http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?",
{SRS:'EPSG:26917',layers: ['bathymetry','road']} );
var options = {
layers: [wms],
mapOptions:{SRS: 'EPSG:26917', minResolution: 1, maxResolution:
500000000},
outsideViewport: true,
size: new OpenLayers.Size(250, 250)
var overview = new OpenLayers.Control.OverviewMap.MapMobility(options);
the only visible tile is:
http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?SRS=EPSG%
3A4326&LAYERS=bathymetry,road&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&S
TYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%
2Fjpeg&BBOX=-180%2C-90%2C243960.625%2C244050.625&WIDTH=256&HEIGHT=256
note that the SRS is wrong and the tile coordinates also seem
suspicious (bottom left is -180 -90 but the projection is a meters
projection).
I've tried so many combinations trying to get something to work that
I am sure it is messed up now.
TIA
Cheers
Paul
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the Dev
