[OpenLayers-Dev] PNG Transparency on IE 6
Steven M. Ottens
steven at minst.net
Fri Mar 2 04:29:57 EST 2007
Hi antonio,
There is a solution; the FixPNG workaround, but it's slow. This is
not a big problem if you have 3 PNG images, but if you enable tiling,
you easily get up to 30 images and it takes up to minutes to draw the
layers. Also with this workaround the images are not displayed until
all the images are loaded and fixed. Which gives your application a
very sluggish feel to it.
More info at: http://homepage.ntlworld.com/bobosola/pngtestfixed.htm
I don't know if OL supports the fixpng workaround, nor do I know they
want to. The solution I use is GIF and opacity on the layers for IE.
It's not as good as transparent PNG, but it's workable.
Steven
On Mar 2, 2007, at 10:05 AM, Antonio Volpicelli wrote:
> Hy ,
> I am using OL on a my application.I have many PNG transparent
> overlapping layers on the same map generated by my mapserver.
> All works fine with the Firefox,Safari,IE7 but doesn't work with
> IE6 for
> a its bug ( *PNG Transparency* in Internet Explorer
> <http://www.pcmag.com/article2/0,1759,1645331,00.asp>)
> Do you know if OL take care of this bug in its code or what could I do
> for that?
> Thanks
> Antonio Volpicelli
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
