[OpenLayers-Dev] problem with unittests for animated zooming
Emanuel Schütze
emanuel at intevation.de
Thu Mar 8 05:54:48 EST 2007
I try to write unittests for my animated zooming code [1] and I get a problem:
I think, the problem is that I want to test asyncronous code, because the
animations of zooming and panning runs by call "window.setInterval(..)".
So, f.e. the call "map.zoomIn()" doesn't work and the unittest runs fail (good
example is test_Map.html; you can run it here [2] ).
If I turn the animation off by calling "map.zoomIn(false)" the test is ok!
Now, I tried it with:
map.zoomIn();
t.wait_result ([seconds])
and
t.delay_call ([seconds], function(){ map.zoomIn(); }).
But both doesn't work!
Can you help me?
Emanuel
[1] http://dev.openlayers.org/sandbox/emanuel/animatedZooming/
[2]
http://dev.openlayers.org/sandbox/emanuel/animatedZooming/tests/run-tests.html
More information about the Dev
