[OpenLayers-Dev] CSS support
Cameron Shorter
cameron.shorter at gmail.com
Tue Mar 13 07:00:00 EDT 2007
I'm pretty gun shy when it comes to CSS. I've seen a number of attempts
to use CSS which worked on one browser, but not on another, or caused
funny things to happen when you create a small or big window, or ...
Consequently, I think the CSS expertise amongst developers is a lot
lower than Javascript expertise and I think we should be wary of asking
developers to use CSS.
This is unfortunate because the vision of CSS is great. I just think we
need to be careful where we apply it.
Christopher Schmidt wrote:
> Browsers often offer a way to 'disable page colors', as a way to turn
> off silly things like the yellow-on-red that so many people love to
> choose.
> However, this setting *also* turns off background images.
> Currently, the Panel/Toolbar code is entirely controlled via background
> images and CSS.
> This means that with the 'use page colors' on, the Toolbar goes away.
> Now, I'm personally of the opinion that if you're turning this off,
> you're likely to see other problems as well, but I would like to hear
> what other people think on this. Can the toolbar code depend on CSS? Or
> is the level of control offered by CSS not enough of a motivator to
> possibly have tools dissappear?
> Regards,
Cameron Shorter
Systems Architect, http://lisasoft.com.au
Tel: +61 (0)2 8570 5011
Mob: +61 (0)419 142 254
More information about the Dev
