[OpenLayers-Dev] BUG: OpenLayers.LonLat.Lon - only with IE 6
Erik Uzureau
erik.uzureau at metacarta.com
Wed Mar 14 19:08:14 EDT 2007
You probably got it from the lonlatfrompx.html file, which is in the
examples directory. It is incorrect and we are going to remove it.
-E
On 3/14/07, Richard Thurbin <richard at cloudamber.com> wrote:
> Thank you very much Christopher. It now works brilliantly.
> Thank you very much also to Erik who gave me some helpful suggestions.
> I will try and dig out where I got the tutorial from so it can be updated.
> Regards,
> Richard Thurbin
> Mobile: +44 7917 704 145
> VOIP: +44 8458 905 299
> Fax: +44 8700 518 913
> Email: richard.thurbin at cloudamber.com
> Cloud Amber Research and Development
> Amber House
> Brockley Road
> Elsworth
> Cambridge
> CB23 4JS
> United Kingdom
> http://www.cloudamber.com
> http://www.carboncalculator.info
> http://www.qbust.info
> -----Original Message-----
> From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
> Sent: 14 March 2007 22:58
> To: Richard Thurbin
> Cc: dev at openlayers.org
> Subject: Re: [OpenLayers-Dev] BUG: OpenLayers.LonLat.Lon - only with IE 6
> On Wed, Mar 14, 2007 at 09:20:14PM -0000, Richard Thurbin wrote:
> > Sorry, I don't know if this is the right way to use this... I would
> > like to report a bug I have found when using the OpenLayers API.
> > I have searched the FAQ, Wiki engine, current tickets, Google and have
> > not found any reference to this.
> I don't have an easy answer for you, but typically the best way to register
> map events is using the map.events.register() call, as in the click.html
> example:
> http://openlayers.org/dev/examples/click.html
> Erik's expressed an interest in this, and I've already pointed him to the
> demo which displays the problem.
> So, in the meantime, you can change your code to use map.events.register as
> in click.html instead of OpenLayers.Event.observe.
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
