[OpenLayers-Dev] WFS Layer, Vector Merge
John Cole john.cole at uai.com
Thu Mar 15 10:50:17 EDT 2007
Hurrah! Hurrah! Hurrah!
I'm really exited about the new changes.  OL is a really impressive system,
and having written my own I know how much effort this endeavor has taken.
Thanks to the whole team.
John
-----Original Message-----
From: dev-bounces at openlayers.org [mailto:dev-bounces at openlayers.org] On
Behalf Of Erik Uzureau
Sent: Thursday, March 15, 2007 12:55 AM
To: Christopher Schmidt
Cc: dev at openlayers.org
Subject: Re: [OpenLayers-Dev] WFS Layer, Vector Merge
Three cheers for the extraordinary effort of Mr. Schmidt, who, in the midst
of mild hallucinatory fever, has continued resiliently pounding away at this
vector branch. Lots of people have put lots of time into getting this code
ready for the merge, but for real, hats off to chris for taking the
initiative to
do this diff... and all the other million motivational/administrational
things
he's done to make vectors in OL a reality.
We're almost there!!!
-e
On 3/14/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> This is my final email for the night (and probably for a couple days on
> OL: I'm only writing this today because illness has kept me up all night
> after sleeping all day.)
> == WFS Layer ==
> Renaming the WFS layer is no longer neccesary.
> As Schuyler pointed out (rightly), we had decided that a featureClass
> determines how the feature is rendered. In the case of Vectors, we can't
> change the features the parser gets back (at the moment), but we can
> just use that as a fallback. If the default Feature Class was being
> used, then the layer will be a vector layer -- if there is no
> featureClass on the layer, that is our fallback state. If there is a
> featureClass, the old markers-style layer is used instead. This
> maintains API compatibility.
> There have been a couple other changes to the WFS layer: it got a lot of
> love it really deserved. It's now a single untiled layer (instead of
> being tiled, which only kind of works for points). If you want more
> points, you should up the points served by your WFS server.
> API hasn't changed at all. The old Owls WFS demo works again, just as it
> did before, displaying markers for points from the layer.
> == Vector Merge ==
> I think this was the last blocker for the vector merge. The
> MouseDefaults and MouseToolbar changes have happened, the renderers all
> work, and the WFS layer has been restored. Before release, we need to
> make sure there is more complete test coverage, and do more testing with
> single file builds, as well as creating a couple of updated build
> profiles to let people get back to the equivilant OpenLayers to the
> pre-vector branch if they choose to. Because the additions to the core
> code are minor -- tiny, even -- the vector branch should be a relatively
> low impact merge. I think my previous email, which pointed out that only
> 5 existing classes have had any modifications at all, is ample to prove
> this :)
> I've kept the branch up to date with trunk as best as possible.
> Hopefully this will lead to a smooth merge process.
> If you have concerns about the merging of the vector branch back to
> trunk, please voice them now. We've added a lot of code, but I believe
> we've done it in such a way as to be unobtrusive. If you want more
> information about what exactly has changed, you can take a look at the
> complete patch to changes in Javascript functionality:
> http://trac.openlayers.org/attachment/ticket/46/vector.patch
> This is an svn diff against everything in lib/ on trunk vs. vector-2.4.
> Please express opinions, positive or negative.
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Dev mailing list
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.446 / Virus Database: 268.18.11/721 - Release Date: 3/13/2007
4:51 PM
No virus found in this outgoing message.
Version: 7.5.446 / Virus Database: 268.18.11/722 - Release Date: 3/14/2007
3:38 PM
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
More information about the Dev mailing list
