[OpenLayers-Dev] List of Layers
Lance Dyas lancelot at inetnebr.com
Thu Mar 15 21:21:39 EDT 2007
TNTmap has a builder component which comes as webapp, hta and dashboard
widget
It does the get capabilities and can help generate Open Layers /
GoogleMaps / Google Earth as well as its own Viewer ... though
the latter will eventually be replaced by an OpenLayers derivation.
The web application uses a perl script to handle cross domain
communication but the hta and widget work directly(except for the Google
Earth KML Reflection)
http://www.microimages.com/tntmap
Antonio wrote:
> Yes  Brad  , that is what I need, just to know all the layers
> available in that site ( that is just my site not any site )
> Sure I will use getCapabilities request to catch them using a external
> php call.
> Thanks
> Antonio
> bradleyspencer wrote:
>> If the site were an OGC compliant site he could use the getCapabilities
>> request to generate a XML file and parse it to determine all the layers at a
>> particular OGC Server? Binding that with the particular request would not be
>> too hard inside JS.
>> I assume he would like this feature as a OL service that say produced a
>> select box of layers from that site. Many OGC clients do this.
>> Just a thought :)
>> Cheers,
>> Brad Spencer
>> General Manager
>> CubeWerx Australia Pty Ltd
>> ABN: 37 115 163 285
>> Mob: +61 (0)404 841 131
>> Tel/Fax: +61 (0)2 9481 7024
>> mailto:brad at cubewerx.com.au
>> http://www.cubewerx.com.au
>> -----Original Message-----
>> From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
>> Sent: Friday, 16 March 2007 8:20 AM
>> To: Antonio
>> Cc: dev at openlayers.org <mailto:dev at openlayers.org>
>> Subject: Re: [OpenLayers-Dev] List of Layers
>> On Thu, Mar 15, 2007 at 09:52:57PM +0100, Antonio wrote:
>>> Hi guys,
>>> I didn't find any method to get info about the layers available on my
>>> mapfile, something that say me how many and how they are named.
>> OpenLayers doesn't talk to the map server you are using to learn about
>> the layers. You need to specify the layers in the javascript setup for
>> your OpenLayers Map.
>>> I can just load a layer from a WMS server specifying a layer name.
>>> Have I to use some php/java scripts to do that, or I am not  looking in
>>> the right place?
>> The functionality that you are looking for does not exist in OpenLayers.
>> Where possible, OpenLayers has taken a 'you can't talk to the server'
>> approach due to the Same Origin Policy. [1]
>> [1] http://en.wikipedia.org/wiki/Same_origin_policy
>> Regards,
>> Christopher Schmidt
>> MetaCarta
>> Dev mailing list
>> Dev at openlayers.org <mailto:Dev at openlayers.org>
>> http://openlayers.org/mailman/listinfo/dev
>        PLEASE WARNING: E-mail is CHANGED
>              volpicelli at oato.inaf.it <mailto:volpicelli at oato.inaf.it>
> Dev mailing list
More information about the Dev mailing list
