[OpenLayers-Dev] Undo/Redo implementation
Eric Lemoine
Eric.Lemoine at camptocamp.com
Sun Mar 18 15:57:33 EDT 2007
Hi OpenLayers dev!
I've been working on adding undo/redo support in OpenLayers.
In my first implementation undo/redo works for PanZoom operations,
i.e. extent operations resulting from user actions on the PanZoom
control object.
The implementation is available here :
<http://svn.openlayers.org/sandbox/elemoine/openlayers/>. See
<http://dev.openlayers.org/sandbox/elemoine/openlayers/examples/history.html>
to see the implementation at work.
The implementation design allows extending undo/redo to other
operations. So if there's interest in this work I could extend it
fairly easily.
I also plan to implement an History Control (Control/History.js). That
control will be composed of a right-arrow and a left-arrow for user to
navigate through the history.
Suggestions? Thoughts?
Thanks,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
