[OpenLayers-Dev] Vector layer fails,
if constructed before the page has finished loading
Jeff Dege
jdege at korterra.com
Mon Mar 19 16:38:45 EDT 2007
OK - further info.
You can't declare a vector layer in inline javascript, you have to
declare it in a function that's called by a client-side event.
The vectorfeatures example declares a vector layer in an init()
function, and init() is called on the onload event of <body>. This
worked.
My ASPX conversion called init() in an emitted Javascript block, placed
near the end of the file
by ClientScript.RegisterStartupScript(). This did not work.
What works:
<html>
<head runat="server">
<title>Untitled Page</title>
<script type="text/javascript"
src="openlayers/lib/OpenLayers.js"></script>
<script type="text/javascript">
var map;
function init(){
map = new OpenLayers.Map( $('map') );
var vectorLayer = new OpenLayers.Layer.Vector("Simple
Geometry");
</script>
</head>
<body onload="init();">
<form id="form1" runat="server">
<div id="map"></div>
</form>
</body>
</html>
What doesn't work:
<html>
var map;
function init(){
Geometry");
</script>
</head>
<body>
<script type="text/javascript" defer="defer">
init();
</script>
</form>
</body>
</html>
The vector layer constructor fails, if it's called before the page has
entirely loaded.
None of the other layers I've worked with have this dependency.
More information about the Dev
