[OpenLayers-Dev] Pb with IE - Events click and mousedown
Sylvain Beorchia sylvain.beorchia at makina-corpus.com
Tue Mar 20 13:14:31 EDT 2007
Using events in OpenLayers, i'm setting these settings :
   map.events.register("click", map, queryMap);
   map.events.register("mousedown", map, clickOnMap);
It works fine on firefox. When i click, querymap is called, and not
clickOnMap. When i start to drag the map clickOnMap is called ok.
But under IE, queryMap is always called. I mean, when i start to grad
the map and then release the mouse button, the "click" event is fired.
a bug ?
Thanks.
Sylvain Beorchia.
Makina Corpus.
More information about the Dev mailing list
