[OpenLayers-Dev] GML Layers is no more visible in vector sandbox revision 2823
Christopher Schmidt crschmidt at metacarta.com
Wed Mar 21 07:43:37 EDT 2007
On Wed, Mar 21, 2007 at 08:49:59AM +0100, Christine Spietz wrote:
> Hi Erik,
> I have updated to the libraries of
> http://svn.openlayers.org/trunk/openlayers revision 2828, but now it's
> working less then before.
> I can not see any map anymore.
> >----------------------------------->ERROR-MESSAGE>----------------------------------->
> OpenLayers.MouseListener.MouseDefaults is not a constructor
> var mouseListener = new OpenLayers.MouseListener.MouseDefaults();
> in Map.js line 229.
> >----------------------------------->END OF
> The thing is: This line (mouseListener = ...) is not contained in Map.js of
> the actual trunk-version of OpenLayers. So I thought I might have embedded
> the wrong OpenLayers-folder in my page, but this is also not the case.
> Do you have an idea, what may have gone wrong? Is it a bug in the actual
> trunk version or what else coul be the cause?
Much of the code between the existing trunk and the old vector branch
was refactored. http://openlayers.org/dev/examples/ has a list of
examples -- including gml-layer and EditingToolbar -- that demonstrate
the new functionality. Please refer to these examples for more
information on how to get started with the trunk version of the vector
tools.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
