[OpenLayers-Dev] Performance problems in changeset [2867]
James Stembridge
James.Stembridge at sandfordtechnology.com
Fri Mar 23 14:07:18 EDT 2007
While improving things in relation to memory usage changeset [2867]
seems to have introduced a pretty unacceptable decline in performance.
I'm finding that removing ~400 markers from a layer takes ~4s, with the
vast proportion of the time spent in Event.stopObserving.
I have attached (I can't seem to do this in trac) a patch that improves
the efficiency of the observer cache with respect to removals, while not
perfect this drops the time taken to remove ~400 markers to a more
respectable 500ms.
Regards,
James.
DISCLAIMER: Important - This e-mail and the information that it contains
may be confidential, legally privileged and protected by law. Access by
the intended recipient only is authorised. Any liability (in negligence
or otherwise) arising from any third party acting, or refraining from
acting, on any information contained in this e-mail is hereby excluded.
If you are not the intended recipient, please notify the sender
immediately and do not disclose the contents to any other person, use it
for any purpose, or store or copy the information in any medium.
Copyright in this e-mail and attachments created by us belongs to
Sandford Technology. The author also asserts the right to be identified
as such and objects to any misuse.
Company no: 04397593 Reg office: 1 City Square, Leeds, LS1 2DP, United
Kingdom VAT no: 789 6572 50
Type: application/octet-stream
Desc: observer_cache.diff
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070323/d41a25f0/observer_cache.obj
More information about the Dev
