[OpenLayers-Dev] select-feature.html on FF 2.0.0.3
Cameron Shorter
cameron.shorter at gmail.com
Thu May 3 17:23:34 EDT 2007
I agree that this is not an issue to delay a 2.4 release and that a
Canvas layer should not be introduced in 2.4.
Christopher Schmidt wrote:
> On Fri, May 04, 2007 at 06:58:33AM +1000, Cameron Shorter wrote:
>> Eric Lemoine wrote:
>>> On 5/3/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
>>>> On Thu, May 03, 2007 at 03:23:20PM +1000, Cameron Shorter wrote:
>>>>> Eric,
>>>>> Good that you have tracked down the Ubuntu/Firefox issue, but we
>>>>> probably should be tracking in the OL issue tracker too.
>>>>> Ideally we should introduce a work around in OL as we don't want to
>>>> tell
>>>>> all Ubuntu users to go install Windows and wait until the next Ubuntu
>>>>> release.
>>>> I can't imagine what kind of workaround we can introduce for "SVG is
>>>> broken in Feisty." I think the answer is simply "Download a real
>>>> FireFox.", since the one in Feisty is apparently broken in ways that the
>>>> official release is not.
>>> Agreed. That is why I submitted a bug to Ubuntu in the first place.
>> I haven't looked into how broken Feisty SVG is broken. You might be
>> right about it not being fixable. By having the bug recorded, we at
>> least have something we can point users at so we don't have to keep
>> answering the same user questions.
> Agreed. I've added it (and a workaround -- download a copy of firefox
> from moz.org) to the VectorFAQ wiki page. It's my plan to merge this
> with the main FAQ at release time.
>> One work around that comes to mind is to use the Walter Zorn vector
>> rendering which is also available for old browsers and would give us
>> vector support in old browsers.
>> http://www.walterzorn.com/jsgraphics/jsgraphics_e.htm
> No, you're missing the point of 'workaround' here -- that's a new
> feature, which solves a host of problems (and introduces a host of other
> problems). I believe that the better solution than *that* is to create a
> Canvas layer, which Firefox supports and would add Safari support to our
> base. However, neither of these are features which make sense in 2.4.
>> Alternatively, we could offer an alert message telling users why the
>> functionality is broken and what they should do about it.
> Except we can't detect that it's broken. (And, since switching tabs
> 'fixes' the display, it's not clear that we're likely to have a simple
> test case.)
> Documenting it and explaining workarounds are great. However, I strongly
> believe this is not something that we should delay a 2.4 release for --
> that's all I'm really saying.
> Regards,
Cameron Shorter
Systems Architect, http://lisasoft.com.au
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
More information about the Dev
