[OpenLayers-Dev] EPSG:41001
Gilbert, Antoine
AGilbert at korem.com
Thu May 17 14:56:27 EDT 2007
Hi
I'm new to OpenLayers.
Not sure I understand myself exactly the question I'm asking
For now I am trying to write my own OpenLayers.Layer implementation.
I use this to build my map object
map = new OpenLayers.Map("map", {maxExtent: new OpenLayers.Bounds(-180,
-85.05, 180, 85.05), units: 'degrees', projection: "EPSG:41001"});
According to this Mercator projection I am assuming my getURL layer
method to be called for bounds related by default to 256x256 pixels
tiles.
I wonder why the bounds passes in the getURL requests have the same
numeric width and same numeric height, I was assuming something around
the 150/85 ratio instead of 1/1...
Antoine
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070517/27b5c564/attachment.html
More information about the Dev
