[OpenLayers-Dev] Patch: fix argument handling in Function.bind()
Christopher Schmidt crschmidt at metacarta.com
Fri May 18 09:27:14 EDT 2007
On Fri, May 18, 2007 at 02:24:42PM +0100, Andy Armstrong wrote:
> On 18 May 2007, at 01:36, Andy Armstrong wrote:
> > The implementation of Function.bind() in BaseTypes.js has a problem in
> > the case where you supply additional arguments to the bound function
> > when invoking it.
> [snip]
> Did I post this to the right place?
The place was right, the mechanism was wrong :) I couldn't turn the text
in the body of the email into a patch. If you could create a ticket and
submit a patch following the directions on
http://trac.openlayers.org/wiki/FilingTickets , I'll mark it for 2.4 and
make sure it gets reviewed.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
