[OpenLayers-Dev] EPSG:41001
Gilbert, Antoine AGilbert at korem.com
Thu May 24 10:16:28 EDT 2007
Ya, even while using the new OpenLayers.Map 41001 constructor example I
still wondering why my getURL method still receiving bounds in long lat
and in the x-y ratio 1-1 for each tile. I was assuming I would get
bounds in the 41001 format.
Antoine
Korem
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: 17 mai 2007 15:13
To: Gilbert, Antoine
Cc: dev at openlayers.org; Houde, Jonathan
Subject: Re: [OpenLayers-Dev] EPSG:41001
On Thu, May 17, 2007 at 02:56:27PM -0400, Gilbert, Antoine wrote:
> map = new OpenLayers.Map("map", {maxExtent: new
OpenLayers.Bounds(-180,
> -85.05, 180, 85.05), units: 'degrees', projection: "EPSG:41001"});
EPSG:41001 is not in degrees, it is in meters.
http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#Projections has
useful extent/resolution for the whole world in that projection.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
