[OpenLayers-Dev] WFS-T demo failing?
Andrea Aime
aaime at openplans.org
Tue May 29 11:40:40 EDT 2007
Christopher Schmidt ha scritto:
> The OpenLayers Development Team is proud to announce the final release of
> OpenLayers 2.4!
I've just tried again the OL version we ship in Geoserver to 2.4,
and noticed it does not work.
A sample insert request coming from that demo is:
<wfs:Transaction
xmlns:wfs="http://www.opengis.net/wfs"><wfs:Insert><feature:tasmania_roads
xmlns:feature="http://www.openplans.org/topp"><feature:the_geom><gml:MultiLineString
xmlns:gml="http://www.opengis.net/gml"><gml:lineStringMember><gml:LineString><gml:coordinates
decimal="." cs="," ts=" ">145.420508203125,-41.5523681640625
146.123633203125,-41.4754638671875 146.431250390625,-41.7061767578125
</gml:coordinates></gml:LineString></gml:lineStringMember></gml:MultiLineString></feature:the_geom></feature:tasmania_roads></wfs:Insert></wfs:Transaction>
This request is non compliant, since
it does not include nor service="WFS" attribute in <Transaction>, nor
the version one.
I know, it may seem obvious, but the WFS Transaction schema is clear,
the service attribute is mandatory:
<xsd:complexType name="TransactionType">
<xsd:sequence>
<xsd:element ref="wfs:LockId" minOccurs="0">
</xsd:element>
<xsd:choice minOccurs="0" maxOccurs="unbounded">
<xsd:element ref="wfs:Insert"/>
<xsd:element ref="wfs:Update"/>
<xsd:element ref="wfs:Delete"/>
<xsd:element ref="wfs:Native"/>
</xsd:choice>
</xsd:sequence>
<xsd:attribute name="version"
type="xsd:string" use="required" fixed="1.0.0"/>
<xsd:attribute name="service"
type="xsd:string" use="required" fixed="WFS"/>
<xsd:attribute name="handle"
type="xsd:string" use="optional"/>
<xsd:attribute name="releaseAction"
type="wfs:AllSomeType" use="optional">
</xsd:attribute>
</xsd:complexType>
Is there any way I can modify the sample to make it generate
a correct WFS-T request? I tried adding service and version attributes
to the WFS layer definiton, but to little effect (and since GetFeature
works, I must assume GetFeature does in fact have the attributes right).
Now, this issue was there in the 2.4-rc3 I tried originally, but
unfortunately due to a series of unfortunate events I did not report it
right away, and then forgot to do so.
So, sorry for reporting this late...
Cheers
Andrea
More information about the Dev
