[OpenLayers-Dev] Different lon and lat map resolution
(and other issues)
Jachym Cepicky
jachym.cepicky at gmail.com
Fri Nov 2 13:37:43 EDT 2007
Tim Schaub píše v Pá 02. 11. 2007 v 10:57 -0600:
> > I can understand this. How many people do have write access to trunk?
> http://trac.openlayers.org/wiki/CLA
> The above page describes who has access to what. As with all else in a
> wiki, this list requires a person to update it - so I can't say how
> current it is, but I think Erik probably is keeping it up.
From what I see in mailing list, only few, who have the access are
really committing something or reviewing patches "from outside". Am I
wrong?
> > what do you understand with "test" ? Is it working demo?
> There are two types of tests that we like to see: acceptance tests and
> unit tests (wikipedia is a good reference for terms like these). In
> general, automated tests are nicer than manually run tests.
> See http://trac.openlayers.org/wiki/CreatingPatches for a link to the
> page on writing unit tests. Our automated tests are really a combo of
> acceptance and unit tests. We also have some acceptance tests scattered
> around the examples directory.
> In short, you should write tests for any modifications. In OpenLayers,
> these tests should be written using the Test.AnotherWay setup. If your
> modification represents a change that can reasonably be shown with an
> example, then your patch should also include an example.
> So, a ticket that proposes a modification should ideally contain *one*
> patch. That patch
> 1) can be applied cleanly to the trunk,
> 2) has inline documentation comments in the NaturalDocs style,
> 3) includes tests that run in our Test.Anotherway setup, and
> 4) includes an example if appropriate.
> You can find more on the wiki that details things here that you might
> not understand.
Sorry, the wiki is not so well-arranged to me (like most development
wikis). Sometimes I miss something. Thank you to clarifying this.
> How does your patch affect vector layers?
They work
> Will it work with the upcoming Proj4js work?
No idea - I'm working with current subversion repository. Do I have to
apply all other proposed changes/patches in order to provide well tests?
> Is your proposed feature compatible with markers, popups,
> world wrapping, commercial layers, and all other
> current features?
If I'm posting a patch, than I can only say: "I tested everything, I
could. It works for me". When I find something, or somebody will report
something, that would not work, I will do my best to fix it.
So, to answer your question: yes, everything works for me.
> A quick glance at your ticket and attached patches
> doesn't answer any of this for me.
Nobody ever asked (since 08/06/07 -- sorry, this seems long time to me).
My previous answer (5 lines above) applies to this as well.
> A more robust (and up to date)
> example and tests would help.
What concrete are you missing? I have running tests on other servers.
Writing another examples just takes time - I have to do some work too.
> And a good understanding of how all these
> other features work is essential to contributing a modification that
> changes map behavior.
I know. Am I supposed to prove, that I understand all of this? How?
But the discussion went too concrete now. General question is: Do you
think, current system is all right? Are there enough reviewers, who are
checking the tracker regularly and communicating with the contributors?
As you probably understand: I do not think so.
Thanks
Jachym
> > And - I'm posting this to dev list only. Should I post to users list as
> > well, to get some kind of support?
> >> If there is interest from others (replies to the list, comments on the
> >> patch), then it would probably make sense to add some tests and make a
> >> single patch for your modification. And yes, if it doesn't apply to the
> >> trunk, it is even less likely to get reviewed.
> > If I understand your last sentence right - we are expected to keep our
> > patches fresh for several weeks or months? If so, I would have to ask,
> > if there could be some better development model(?).
> > It is not going only about this one issue - I have several other
> > improvements, Marker/Label.js, Popup.js, LayerSwitcher.js and others.
> > But I'm asking myself, if it is worth the work, to prepare patches, if
> > nobody even reviews them :-(
> > Thanks for your answers
> > Jachym
> >> Tim
> >> Jachym Cepicky wrote:
> >>> Hi,
> >>> I submitted new patch set to #889 [1], which implements different pixel
> >>> resolutions in x and y direction. The patches should work with *current*
> >>> version of OpenLayers.
> >>> I would also like to ask several questions:
> >>> - when approximately the patch will be added to trunk, or
> >>> - when approximately will be decided, this will/will not happen
> >>> - what else can I / do I have to do for, the patch will be accepted or
> >>> definitely declined
> >>> - do I have to prepare fresh patches let say every week, so they are
> >>> still usable for current OpenLayers, or is it enough, post them once,
> >>> the project managers will update them by themselves?
> >>> Now, I did 3rd version of the patch, till now, there was even no
> >>> discussion, if the patch should/should not/should under some conditions
> >>> be accepted/declined.
> >>> Sorry, if this sounds rude - this e-mail is not to be understood as
> >>> blame. It is just little bit frustrating: If the people are asking for
> >>> new features, most general answer is "patches are welcomed". If the
> >>> patches are there, nobody wants them. Or, so it looks at least from
> >>> here. That is, why I'm asking about the mechanisms of patch
> >>> acceptation.
> >>> Thanks
> >>> Jachym
> >>> [1] http://trac.openlayers.org/ticket/889
> >>> _______________________________________________
> >>> Dev mailing list
> >>> Dev at openlayers.org
> >>> http://openlayers.org/mailman/listinfo/dev
> >>> !DSPAM:4033,472b3b42219125210051143!
> >> Dev mailing list
> >> !DSPAM:4033,472b4c68280415332866982!
> Dev mailing list
Jachym Cepicky
e-mail: jachym.cepicky at gmail.com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20071102/5471cc53/attachment.bin
More information about the Dev
