[OpenLayers-Dev] createLiteral benchs
Andreas Hocevar
andreas.hocevar at gmail.com
Wed Nov 7 07:29:00 EST 2007
thanks Pierre for putting together this profiling application! It
helped me to think about the whole thing again, and I found an elegant
method that works with one regex-based split and without
String.replace. It scales linear with both the number of style
attributes and the number of variables to replace in the attributes,
which makes it superior to the other methods in most cases:
http://dev.openlayers.org/sandbox/ahocevar/sldRenderer/examples/profilingAttributeName.html
${name}
feature
returned value : foo
andreas' method: 16ms
pierre's method: 21ms
andreas' method 2: 28ms
feature2
andreas' method: 30ms
pierre's method: 20ms
andreas' method 2: 26ms
feature3
andreas' method: 51ms
pierre's method: 23ms
andreas' method 2: 27ms
name: ${name}, age: ${age}, address: ${address}, status: ${status}
feature
returned value : name: foo, age: ${age}, address: ${address}, status: ${status}
andreas' method: 17ms
returned value : name: foo, age: undefined, address: undefined,
status: undefined
pierre's method: 69ms
returned value : name: foo, age: age, address: address, status: status
andreas' method 2: 55ms
feature2
returned value : name: foo, age: 20, address: somewhere, status: single
andreas' method: 36ms
pierre's method: 574ms
andreas' method 2: 54ms
feature3
andreas' method: 65ms
pierre's method: 65ms
andreas' method 2: 56ms
Regards,
Andreas.
More information about the Dev
