[OpenLayers-Dev] layer opacity
Sébastien Roch roch.sebastien at gmail.com
Thu Nov 15 08:47:07 EST 2007
Yep I'll do this (ticket + maybe patch)
On Nov 15, 2007 12:49 PM, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Thu, Nov 15, 2007 at 12:46:58PM +0100, S?bastien Roch wrote:
> > Hello,
> > I've been playing with layer opacity, and noticed something wrong if I
> > try to set opacity to 0 : doesn't work...
> > After a quick look in the code, it's simply this line in function
> > modifyDOMElement (Utils.js) where the issue is :
> > if (opacity){
> > 0 gives "false" in a boolean context.
> Cool. Make a ticket? With a patch, if you can; with a patch and tests if
> your'e feeling extra brave :)
> Regards,
> Christopher Schmidt
> MetaCarta
More information about the Dev mailing list
