[OpenLayers-Dev] ModifyFeature for Geometry.Rectangle and others
Patrick Valsecchi
patrick.valsecchi at camptocamp.com
Fri Nov 16 03:25:23 EST 2007
Hi Tim,
On Thursday 15 November 2007, Tim Schaub wrote:
> I don't want to support Geometry.Rectangle. I think it was an accident
> to let it in the trunk, and I hope it goes away.
Why would that be a mistake? Because there is no rectangle in the OGC spec?
Why should we limit ourself to what the OGC defines? I'm sorry, but I can see
rectangles and circles in the OGC spec. Maybe not as features, but in the
OpenGIS standard, I see rectangles and circles in the form of "bounding box"
and "WHERE ST_DISTANCE(center, geometry)<radius".
Yes, you can represent a rectangle with a polygon, but you loose the
information its a polygon. Yes, you can approximate a circle with a polygon,
but you loose information and precision. Yes you can add some info to the
polygon to tell it is regular or it is a rectangle, but it's going to be hard
to interpret this information.
In the application I'm working on, it's not features the user is drawing, its
a query. That's why I need circles (all the features in a certain distance)
and rectangles (they want rectangles). And no, a polygon cannot replace a
circle in this case. So I have to translate the polygon into a circle. And
event with 30 nodes, the "circle" in my map looks ugly when you zoom in. And
I don't mention the performance problems with SVG.
For me, we should support all the shapes the end user (the one behind his
browser and that don't care about the limitations of the OGC) will need. That
means circles, bezier curves, ... . And if "crazy" shapes like that have to
be sent to a WFS service, then they can be translated into approximative
polygons or polylines by the formatter. But, again, you'll loose some
information. But at least programmers dealing with less limited services
won't suffer.
I would not have any problem with the absence of rectangles and circles if
OpenLayers was allowing to easily add new shapes. But, the way it is now,
it's very hard to do it. Maybe we should go more in the direction I took with
my ModifyFeature patch proposal and allow the user to add "handlers" for
non-standard shapes. That means stop doing series of "if"s on the CLASS_NAME
in the renderers/formatters and start using a hashmap instead. That way,
crazy users like me can add support for new shapes without bothering the
others with stupid emails like this one. ;-)
By the way, if we really want to stick to the OGC definition of geometries,
then we have a few bugs in OpenLayers. It shouldn't allow the creation of
invalid polygons (for example self intersecting ones). But that one is going
to be tough to implement in JS.
Thanks.
More information about the Dev
