[OpenLayers-Dev] [crschmidt@metacarta.com: [OSM-dev] Faster
Commercial Layers]
Erik Uzureau
erik.uzureau at metacarta.com
Fri Nov 23 16:55:22 EST 2007
So Im running this example over again today and now it seems like it
*is* working.
Can anyone out there on the list run this:
http://openlayers.org/dev/examples/smoothDragging.html
in IE6 and or IE7 and verify that it's ok?
thanks up front,
e
ps. if you're getting a gmaps error, that should go away shortly....
i've updated the html file in svn but sometimes it takes a while to
get propagated
On 11/21/07, Paul Spencer <pspencer at dmsolutions.ca> wrote:
> Chris,
> this works really well for me in firefox on macosx. Excellent find.
> Paul
> On 21-Nov-07, at 8:20 AM, Christopher Schmidt wrote:
> > Sigh. Sending emails at 3:45 is worse than committing at 3:30. This
> > went
> > to the osm-dev instead of ol-dev list.
> > -- Chris
> > ----- Forwarded message from Christopher Schmidt <crschmidt at metacarta.com
> > From: Christopher Schmidt <crschmidt at metacarta.com>
> > To: dev at openstreetmap.org
> > Date: Wed, 21 Nov 2007 03:49:34 -0500
> > Subject: [OSM-dev] Faster Commercial Layers
> > The three commonly used commercial layers -- Google, VirtualEarth, and
> > Yahoo -- now each have a mechanism using the internals of their
> > respective APIs to grab faster ways to move map tiles around.
> > http://openlayers.org/dev/examples/spherical-mercator.html now
> > demonstrates this.
> > Erik reports that IE is throwing an error. Since is it 3:45 in the
> > morning, I'm going to go to sleep now, get an early start and try to
> > hack on the IE issue first thing before work, and get it resolved.
> > In the meantime, Firefox browsers might be interested in checking the
> > uRL above and checking out the other APIs.
> > (Note that Yahoo/VE both have weird ideas about what to do when
> > viewing
> > the whole world -- best to zoom in a couple notches.)
> > Additionally, there is an option on the EventPane layer class:
> > {Boolean} smoothDragPan determines whether non-public/internal API
> > methods are used for better performance while dragging EventPane
> > layers.
> > When not in sphericalMercator mode, the smoother dragging doesn’t
> > actually move north/south directly with the number of pixels moved,
> > resulting in a slight offset when you drag your mouse north south with
> > this option on. If this visual disparity bothers you, you should turn
> > this option off, or use spherical mercator. Default is on.
> > Feedback welcome; I'm hoping that at least some if it will be positive
> > Regards,
> > Christopher Schmidt
> > MetaCarta
> > dev mailing list
> > http://lists.openstreetmap.org/cgi-bin/mailman/listinfo/dev
> > ----- End forwarded message -----
> > Christopher Schmidt
> > MetaCarta
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> |Paul Spencer pspencer at dmsolutions.ca |
> |Chief Technology Officer |
> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
> Dev mailing list
More information about the Dev
