[OpenLayers-Dev] limitation of fix #487 to wrap the dateline
pdecker
paulad at rmi.net
Fri Nov 30 16:32:35 EST 2007
Hello,
I have seen a fix for version 2.5, #487 to wrap the dateline; its
limitations were described by OpenLayers below. Will this allow me to
display an image with a bounding box which crosses the international
dateline using the WMS layer? Could someone explain the limitation listed
below?
Limitations/expectations of this patch:
Requests which cross the date line are *not* wrapped, so they will request
content outside the world if it does not divide evenly.
Thank you so much.
-PDecker
View this message in context: http://www.nabble.com/limitation-of-fix--487-to-wrap-the-dateline-tf4924594.html#a14093713
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
