[OpenLayers-Dev] singleTile optimization
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Oct 4 22:04:34 EDT 2007
Christopher Schmidt wrote:
> On Thu, Oct 04, 2007 at 11:09:34AM -0500, Erik Uzureau wrote:
>> There we go. What David's said here is what I was grasping for earlier here.
>> If you use a singleTile layer that is gridded, *eventully* the user is
>> going to pan the map such that the corners of the grid are in the
>> viewbox. At that point, the only option is to load 4 tiles, at which
>> point, we're back to gridded, in which case you might as well just use
>> a normal gridded layer with a very big tilesize and a buffer:0
> I think Paul is imagining a singleTile which matches the grid of a
> *smaller* set of tiles -- so the gridded tile is 'snapped' to a corner
> of a smaller grid. For example, you could imagine the grid existing at
> 0.5 degree increments all the way across the world, and the tile would
> snap to the closest one. The tile no longer has equal buffer space on all
> outside edges, but is more cachable.
> The size of a single grid square must be smaller than the smallest area
> that can outside the map at any given time, so when the new area is
> requested, the tile 'jumps' to fill it, but positions itself based on
> the grid instead of based on the map center.
> Regards,
OR that the single tile is always rounded up so that the off screen
corners snap to a tile vertices, but it is centered on the appropriate
point in the viewport.
Think of it as a single tile with a buffer, but the buffer is always
snapped to the nearest tile vertex that is off screen. This just makes
the image somewhat more cache-able at the expense of larger images. and
you could slide the image up to the buffer edge without requesting a new
image.
I am not suggesting that we do this, only that it is another
interpretation of Pauls request.
The other reason that people might want to run singleTile models is that
they do not want the overhead of setting up a tilecache and managing it.
For example, I do a lot of small low volume pages that do not need
tiles, it would just needlessly complicate things.
-Steve
More information about the Dev
