[OpenLayers-Dev] Adding nautical miles and yards to units
Christopher Schmidt crschmidt at metacarta.com
Fri Oct 5 11:26:27 EDT 2007
On Fri, Oct 05, 2007 at 03:32:06PM +0100, Ian Mayo wrote:
> Hi,
> the maritime GIS community work in yards and nautical miles, so the
> following lines could be added to util.js
> OpenLayers.INCHES_PER_UNIT["yd"]= 36;
> // a yard is 36 inches
> OpenLayers.INCHES_PER_UNIT["nmi"]= 1852 * OpenLayers.INCHES_PER_UNIT["m"];
> // a nautical mile is 1852 yards (http://en.wikipedia.org/wiki/Nautical_mile)
here you use '1852 * m', but it seems like this should be 1852 * yd.
Also, I think 'nm' is the better abbreviation.
> How do the community feel about adding maritime units to OpenLayers?
Indifferent, but it seems unlikely to hurt anything :)
> I appreciate developers can insert the above lines directly into the
> custom applications, but suspect a better home is in the trunk.
I'm generally okay with this. Can you put together a patch and file a
ticket?
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
