[OpenLayers-Dev] Design for scale-line
Paul Spencer
pspencer at dmsolutions.ca
Mon Oct 8 16:53:05 EDT 2007
On 8-Oct-07, at 4:01 PM, Ian Mayo wrote:
> thanks again for the feedback, comments below...
:) looking forward to having this in trunk ...
>> 3) If the units are decimal degrees, you should adjust the
>> calculation based on the current latitude of the center using the
>> cosine of the latitude. This was from a distance measuring tool I
>> did a while back:
>> d = d * Math.cos(2 * Math.PI * map.center.lat / 360);
> Ooh Paul, you couldn't just point me to where/how I need to switch my
> algorithm to accommodate this? Is it right at the start when I
> convert the maxSizePx in pixels to data units?
I didn't spend any time looking at where to put this :( If you are
having trouble, I can take another look ...
Cheers
Paul
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the Dev
