[OpenLayers-Dev] RFC: Changing the License on OpenLayers
Cameron Shorter cameron.shorter at gmail.com
Wed Oct 10 15:08:47 EDT 2007
+1
My concerns are already noted, but I don't want to see graduation
blocked by the separate, long winded process you are likely to have on
your hands getting acceptance of the Clear BSD license.
Schuyler Erle wrote:
> * On  9-Oct-2007 at 10:53PM PDT, Cameron Shorter said:
>> +0
>> (changed to +1 if +0 is considered blocking)
>> As noted on PSC email lists, I don't like the proliferation of Open
>> Source licenses. I understand Metacarta's concerns regarding the
>> ambiguity of the BSD license and think they are valid.
>> I'm encouraged by Metacarta's intent to propose the "Clear BSD" be
>> incorporated into the next version of the BSD. However I'm concerned by
>> the delay engaging the BSD community, and it seems no resources are
>> allocated to the task.
> I think we agreed by consensus that a +0 would block a license change.
> Our informal understanding with Howard and Frank is that the Clear
> BSD, as Chris indicated, is sufficiently similar to existing BSD
> licenses that, given the existing precedent with GDAL, the OSGeo
> Incubation Committee and Board of Directors are likely to accept it as
> falling well within the spirit of other OSGeo-approved licenses.
> It's very important that we have a strong consensus within the PSC
> before moving forward. Cameron, can we get either a +1 from you, or a
> more detailed explanation of your concerns so that we can ensure that
> they get addressed?
> SDE
Cameron Shorter
Systems Architect, http://lisasoft.com.au
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
More information about the Dev mailing list
