[OpenLayers-Dev] OpenLayers.Popup status
Lance Dyas
lancelot at inetnebr.com
Fri Oct 12 20:35:22 EDT 2007
Christopher Schmidt wrote:
> On Fri, Oct 12, 2007 at 07:10:58AM +0200, Jachym Cepicky wrote:
>> hi,
>> I wanted to ask about the status of "Google" popups in OpenLayers. I
>> managed more or less to port example from Richard Thurbin [1] to current
>> trunk version of OpenLayers. However, as far as I saw, the code uses
>> different approach for Popup decorations (images vs. rico rounded
>> corners) and other details. So, I would like to ask, if it makes sense
>> to continue in the porting and clean the code little bit, so it could be
>> merged to trunk
>> or
>> if completely different approach is to be used and there is already
>> defined concept or living demo, which will go to trunk in the future.
> It is expected that the work done on the CloudAmber popups will be moved
> into trunk directly -- the rico rounded corners style popups simply
> don't have the ability to do what people want as far as 'pretty' look
> and feel, so we're going to need the option that the CloudAmber popups
> provide.
> I do not think we've done neough investigation to figure out the exact
> method of plling them in, but writing tests, etc. for them at this point
> is likely to be extremely beneficial and accelerate acceptance into
> trunk, even if things change.
> Regards,
how about SVG / VML popups for the progressive ;-)
I dont have many maps this wouldnt work for... you could
even fall back to rico cornered popups for those very very
very few poor souls without SVG or VML..
More information about the Dev
