[OpenLayers-Dev] Problems with vector in projection epsg:3021
Swärd Mårten marten.sward at smhi.se
Tue Oct 16 05:32:25 EDT 2007
Hello folks!
I've tried to draw a polygon on a map with projection epsg:3021, I've managed to get the polygon to be drawn to the map but the problem is that the shape doesn't show util you relese the mouse button. I guess that the problem is that I have to set the projection (epsg:3021) on something more than just the map and the vector-layer, or..?
With the options to DrawFeature you can change the color on the polygon, is it somewhere here to that I should change the projection?
Best regards: Mårten
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20071016/d987d771/attachment.html
More information about the Dev mailing list
