[OpenLayers-Dev] jslint results
Paul Spencer
pspencer at dmsolutions.ca
Tue Oct 16 14:31:01 EDT 2007
Thanks Erik. Before I go ahead and make a bunch of changes, though,
I'd like some feedback on how pedantic we should be about certain
coding practices. I'd like feedback from the core devs on the
following things:
1) use of semi-colons
Should we care about certain edge cases, such as:
var f = function(){return true};
will say that you need a semi-colon after true (inside the block
scope of the function)
2) use of curly braces around block scope
Should we care about one line cases and implied scope, such as:
if (this.singleLayer) return;
for (var i=0; i<this.grid.length; i++)
if (this.grid[i].length) {
3) unreachable code
function foo() {
return true;
var test = 1;
4) missing break statements, missing break in last case of switch
5) leading or trailing decimal points
.000
000.
6) nested comments
/* comment
There are quite a few more options that can be used too, but are
disabled by default because they have more of an impact on coding style.
I personally like the ones above because they are situations that can
lead to erroneous code in a multi-developer environment.
I am also not advocating that we fix every warning that comes out of
the tool, but rather that it can help us focus on specific potential
problem areas - i.e. not using break statements in a switch is a
reasonable technique in some instances.
Please give me feedback on whether you want me to vet the code for
the above issues or not. I will make a single commit with all the
changes on the current trunk once it is decided what we should or
shouldn't include. Thereafter, I will check trunk occasionally,
especially before we cut a release, and do touch ups as required.
Cheers
Paul
> As a core committer, you should feel free to make these changes as you
> see fit. OpenLayers has a (somewhat unstated) policy that
> non-functional patches need not go through the standard
> ticket/approval system.
> ...which means that if you want to replace a missing semicolon or tab
> out a line or add a comment or something like that, you should just go
> ahead and do it. As long as it doesn't change the functioning of the
> code.
> Erik
> ps. thanks so much for taking the time to run this analysis. Looks
> like our code has not a few little oversights!
>> The regular expression one I am not so sure about. Anyone know
>> anything about javascript syntax in this particular case?
>> Cheers
>> Paul
>> |Paul Spencer pspencer at dmsolutions.ca |
>> |Chief Technology Officer |
>> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
