[OpenLayers-Dev] Layers into Groups
Steven M. Ottens steven at minst.net
Wed Oct 17 05:23:01 EDT 2007
The mapbuilder code uses
//wmc:ResourceList/wmc:Layer[wmc:Extension/wmc:Group/@name=$GroupName]
So this means that it selects the layers which have a group-extension. I
believe the structure is hierarchical, so using group/layer approach
should be consistent with the OWS spec.
But I'm not the real expert, I though gertjan did the grouping code, but
could be wrong.
Steven
Cameron Shorter wrote:
> Grouping layers has been discussed a few time on the Mapbuilder list, in
> particular including Grouping in the OWS Spec.
> It would be good to confirm that your grouping code is consistent with
> Mapbuilder and OWS Context to ease future integration issues.
> I think Steven is probably the expert in this area.
> Lorenzo Becchi wrote:
>> Cool Jachym.
>> that's a good idea.
>> It can even represent the complete structure of a WMS GetCapabilites
>> (read: WMS Manager [1]).
>> At the code sprint in Victoria, we where talking with Chris about the
>> possibility to add few features to LayerSwticher. This could be one.
>> other possible attribute wired features:
>> - "buttonDropLayer" : true //activate a button to let the user drop the
>> layer from map and layerSwitcher
>> - "buttonZoom2Extent" : true //show a button to zoom to layer extent
>> - "buttonOpacity" : true //show two buttons change layer opacity
>> - "buttonMoveLayer" : true //show two buttons to move layers up or down
>> in the overlay list (this could collide with your structure)
>> this are the buttons that could apply to all type of layers.
>> button could be just a div where all styles are defined inside the CSS.
>> if you and others agree we can expand your Ticket or make another that
>> can manage all points. Or make a lots of tickets...
>> ciao
>> Lorenzo
>> ps: btw, your patch doesn't work on Safari 2.
>> [1] *http://tinyurl.com/2fjbr7*
>> Jachym Cepicky wrote:
>>> Hi developers,
>>> I have implemented ordering map layers into groups [1]. You have to
>>> specify new layer attribute group:"Group Name", e.g.:
>>>  var dm = new OpenLayers.Layer.WMS( "DM Solutions Transit",
>>>                 "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap",
>>>                 {layers: "rail,road",
>>>                  transparent: "true", format: "image/png"
>>>                   group:"Transit"
>>> You can define group hierarchy using "/" mark:
>>> group: "Transit/Roads"
>>> Only changed file is LayerSwitcher.js
>>> For example see [2]
>>> Hope, you'll like it
>>> Jachym
>>> [1] http://trac.openlayers.org/ticket/1086
>>> [2]
>>> http://dev.openlayers.org/sandbox/jachym/openlayers/examples/layer-groups.html
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
>> Dev mailing list
More information about the Dev mailing list
